| | | Forums66 Topics128,036 Posts1,055,460 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 17 New Guy | | New Guy Joined: Nov 2011 Posts: 17 | what is the best way to replace cab corners on a 1950 chevy 3100?
Thomas | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Getting someone else to do it for free  otherwise MPandC posted this yesterday here Welding joints and it should answer most of your questions.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I used those as well, and no complaint. I did only use the bottom half on my corner since it wasn't to bad and then was able to use the remaining top half for the rust pocket I had just forward of the door. took a bit of shaping but the curve was actually very close...fyi
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | Ive got an extra cab that is junk and am going to try to cut the top cab corners and shape them to try and make something close enough to the lower corners.if on mock up it doesn't look quite right i'll buy them from classic parts. | | | | | Joined: Nov 2011 Posts: 17 New Guy | | New Guy Joined: Nov 2011 Posts: 17 | Yea I think I will probably go with the corners from classic parts my self...all I need is a welder..lol | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | |
