| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | I am trying to replace some broken lugs on my 49 1/2 ton. I have beat them with a hammer, applied heat and still cannot get them to budge. Does anyone out there have a solution to this problem??? Also what is the size of these lug bolts. Thanks for any help and advice. | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | I used a hydraulic press to remove and replace them on my truck. They are a very tight fit. The thread size should be 7/16" UNF. | | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | I had the same issue - I tried to pound out the front with no luck. Later I learned that a brake shop has to "swag" the studs using a press - not something to do at home. (I felt very ignorant once again for the time spent pounding and cursing!) | | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | I do appreciate all the responses. What kind of ball park price are we looling at for the hydrolic tool to remove these and have you been able to use this tool on any other projects??? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I had a couple real stubborn and cut them off then drilled them out. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the first tool Tim linked is the only type of thing that you might use for other jobs, but the studs can be overcome with patience
originals are usually swedged so they won't walk if the lug nuts come loose, this may be visible as "chisel marks" on the heads, using a big cold chisel against the side of the head where the marks are might loosen the stud - if not, try drilling from the backside with a bit at least 1/2 the diameter of the threaded end - center punch it well so it stays centered - drill deep enough to be past the knurling - then turn it over and with a short piece of heavy wall pipe around the stud head, try the BFH again
Bill | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | Take and soak them with a spray can of PB Blaster as they might have some corrsion issues. I used a Cross Peen Hammer to get two of mine out then sprayed them with PB. when I pulled them in with the old lug nuts and some washers and a impact wrench. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Dec 2011 Posts: 55 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 55 | R the front axles easy to remove anybody want give me a how to. About to remove the front stud on my 51 3100 but need advice first. Some one please help thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | R the front axles easy to remove anybody want give me a how to. About to remove the front stud on my 51 3100 but need advice first. Some one please help thanks Front axle removal. Not hard at all. Disassembling the parts on the axel might be a little more difficult. What front stud are you referring to? | | |
