2 members (78buckshot, Wheelie),
131
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | How the heck does the door gasket rubber fit in the track that goes around the door? I was able to slide one section of it in, but then it was in the way of itself to try to slide it into the next section. There are 2 gaps in the track on each side of the door toward the top of the window with a hole drilled in the middle of the gap. What are these there for? I'm assuming I'm supposed to put the rubber in all in one piece? Any help would be great
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Yes, you have to slide the "Windlace" rubber all the way around the track. One tip is to take a small piece of the windlace and slide it thru the track, checking to making sure the track is not crimped/flatten out. You can spray some silicone or WD-40 on the rubber, or soapy water. It's a job, but once you get the hang of it, it gets easier. You'll have to push the rubber then pull the rubber thru the track. | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | A lot of people, myself included, are able to get one section slid in place as you describe but end up poking it into the channel with a blunted tool for most of the rest. I used a tool used to help install window glass. The curved sections are a little more difficult and most people seem to end up with a pucker in the rear corner.
Chuck
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | And LOTS of dish soap,frist check the track ,than take a cup of dish soap and a small painters brush ,soap up the track and the rubber and push some than pull it ,push than pull it takes time.
Pete | | |
