5 members (Bill Hanlon, Jon G, 2-Ton, 50Chevy3100, 1 invisible), 159 guests, and 3 robots.
Topics128,110
Posts1,056,257
Members48,437
#822177 02/02/2012 1:26 PM
I
I Offline
Hi all,
1st post so sorry if this has been covered before. Did a search and came up empty.
The gas tank in my 65 must have a small leak and I need to either seal it or replace it. I'd prefer not getting a Chiwanese gas tank, but is there anyone making them in the good ole USA?
Just replaced the water pump about a month ago and even it was made overseas. Still bothers me having that on there.
Dan
Walter's 65 Shop Truck
1965 Chevy 1/2-Ton
More pix on Photobucket
Good luck. Maybe find a good used unit?
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I
I Offline
I wouldn't mind a used tank if I can find a really clean one. I don't want to go used and end up right where I am. Just thought if good reproductions are available made here, I'd go that route.
Dan
1965 Chevy 1/2-Ton
If the leak isn't major , you might fix it with the gas tank sealer that several vendors sell .
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
I
I Offline
Quote
I may end up doing that, I've had good luck with motorcycle tanks in the past. It is a small leak.
Dan
1965 Chevy 1/2-Ton
You might try your local radiator repair shop. I've had a number of gas tanks fixed by them.
I
I Offline
Quote
Now that's an idea I never thought of, I'll check and see if he's game.
Dan
1965 Chevy 1/2-Ton
