0 members (),
134
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | I have seen 1/2 and 3/4 ton chevys with 8lug 16x6 wheels did they make 1-tons with 16x6 rims? I have 17.5 rims (not duallys)and it's getting hard to find tires, i have tried to use 70-80s wheels but they are to wide on the front and hit the tierods late model wheels are metric and don't fit the old lug patern, would old 16x6 rims fit my ton? or would they be to small to clear the tierods? i can fit the 70-80s wheels with a 1 inch spacer on the front hub, but that would cause the wheel studs to be to short to tighten up the wheel, and i wouldn't want to space the front wheels that far, anybody got any ideas? | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Take a look at Ford 16.5 x 6.5 8 lug wheels from the '70s. They work fine on my 1969 C20.
best wishes, Les | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | I use 16x6s on my 51 1 Ton and they work fine.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I have 16x6.5 from a Ford van on my 54 truck. There is less than 1/4" of clearance, but they fit. I know of some other guys that have tried this, but had no luck. There are also companies out there that make 16" 8 lug rims for trailer. Again, some guys say they fit, others not so much. Your best bet is to get a couple different rims from the junkyard and see what works for you. | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | I understand that you can now buy new wheels. I think it is Wheel Vintiques or one of those conpanies that offers 8 lug wheels. By the way, it looks like Stockton Wheel is back in business. | | | | | Joined: Oct 2009 Posts: 9 New Guy | | New Guy Joined: Oct 2009 Posts: 9 | I went with 17.5 mud&snow, $175 ,$40 shipping for each tire. For my 1967 c-30 Carl
