8 members (Gray_Ghost, Biermann, Hugh63c10, SmalltownTRKGuy, Phak1, Buckeye998, Gdads51, dt235sd),
138
Mod | | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 6 New Guy | | New Guy Joined: Sep 2011 Posts: 6 | I've tried two different vendors in hoping to find the correct windshield wipers for my 1954 3100 1/2 Ton Chevy Pickup. They both sent me setups in which the blade travels above the windshield. Has anyone else had this problem and found a resolution? | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Howdy. A problem I had on my 1965 c10 when I bought it... the wiper arms were not the stock ones for a 1965 c10. OOooops. I'm still not sure what they are off of. The originals ones, from what I read didn't work so great anyway. So I mention this only because you want to make sure that the arms on there are for your truck first. You can look the in gallery pages and photos to compare. Now... check out these two sites: billy bob 1955 1st series chevy - LAROKE and 1954 chevy - Alan Horvath Both are Stovebolters... and they document lots and lots of information about their '54-'55 trucks on their websites. Good luck! -W | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Here's my tutorial about installing an electric wiper unit in my '54 ... and there's info about wiper blades and where to get them, too: http://www.AlanHorvath.com/54chevy/wiperarms.phpThe main thing, really, is to determine the length of the wiper blade ... everything else is about the style of arms you have. Alan
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Jul 2000 Posts: 581 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 581 | I ran into the problem in '07. Took me awhile to find my log entry addressing the problem after Woogeroo PM'd me regarding your problem. Here's the pertinent excerpt from my log entry. In the previous log entry I posted on monday, I documented that the eleven inch windshield wiper blades for BillyBob were too long and getting caught under the gasket at the top of the windshield. I jerry-rigged the wiper blades by cutting 1/4" off the offending ends and crimping the other ends so that they would not fall apart as a temporary solution. One of BillyBob's fans at American Classic Truck Parts read the log entry and sent a pair of ten inch blades that fit perfectly! For those of you '54 - '55 1st Series Chevy and GMC truck owners who have run into the same problem of the eleven inch blades being too long, the American Classic Truck part number is "WW129" and the description is "47-53 WIPER BLADE TRICO MODERN NORMAL LENGTH 10 INCHES". | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Thanks for chiming in, fellas!
-W | | |
