7 members (52Carl, joe apple, Otto Skorzeny, 55shaker, Gray_Ghost, Hush, JW51), 147 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
Custom Title
Custom Title
How the heck does the door gasket rubber fit in the track that goes around the door? I was able to slide one section of it in, but then it was in the way of itself to try to slide it into the next section. There are 2 gaps in the track on each side of the door toward the top of the window with a hole drilled in the middle of the gap. What are these there for? I'm assuming I'm supposed to put the rubber in all in one piece? Any help would be great
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
Y
Y Offline
Yes, you have to slide the "Windlace" rubber all the way around the track. One tip is to take a small piece of the windlace and slide it thru the track, checking to making sure the track is not crimped/flatten out. You can spray some silicone or WD-40 on the rubber, or soapy water. It's a job, but once you get the hang of it, it gets easier. You'll have to push the rubber then pull the rubber thru the track.
A lot of people, myself included, are able to get one section slid in place as you describe but end up poking it into the channel with a blunted tool for most of the rest. I used a tool used to help install window glass. The curved sections are a little more difficult and most people seem to end up with a pucker in the rear corner.
Chuck
And LOTS of dish soap,frist check the track ,than take a cup of dish soap and a small painters brush ,soap up the track and the rubber and push some than pull it ,push than pull it takes time.
Pete
