Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (rick46ia, TexasJim50, Steelonsteel, baldeagle, Rusty Rod, thekid1950), 59 guests, and 3 robots.
Topics128,006
Posts1,055,268
Members48,418
I have a 1946 Chevy truck that I'm restoring. I have been searching the net for which regulator to use. The site for Delco Remy says to use the regulator that goes with your generator! OK How do I know??
Harold
1946 voltage regulator, approximately 35 amps 6v
http://chevy.oldcarmanualproject.com/chevyresto/4686.htm
What is the "Delco Remy" site?
DG
Denny G
Sandwich, IL
Tim,
Thanks for the info. There are a lot of Regulators on Ebay but if you do not know what is needed you wind up wasting $$$$$
Denny,
Its not really a Delco Remy site. It is a Delco Remy Service Bulletin. Full of good information.
http://www.stinsonclub.org/PublicTech/YahooGroup/Delco-Remy%201R-116%20(regulator).pdf
Harold
Harold
see above
Harold
Harold
Ok, thats the DR service info that is posted over on TOCMP, I my
guess is they snitched it from Keith's site.
The only regulator the you will be able to get is going to be
the Standard Motor Products VR-1. Most autoparts and
reproduction vendors carry it and as Tim pointed out it will
control the 6 volt 35 amp generators which were the standard
back in the day.
DG
Denny G
Sandwich, IL
I once bought a brand new regulator at a swap meet. It had no name on it and when I opened it up, there were no screws anywhere. It tested out just fine but I don't think one could adjust it.
1951 1 Ton Completed
The ones without adjusting screws are adjusted by bending the spring anchors. It takes a little practice, but once you get the hang of it it's easy. It's definitely necessary to have a good accurate ammeter to adjust a regulator.
And always adj them by releasing pressure on the spring then start adding press till the desired setting is achieved.
What I was describing was a unit with no screws at all, not even assembly screws. I am familiar with the older ones that have no adjustmet screws.
Fred, is that the voltage regulator I have in my bus now? -It works like a champ!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Christopher,
that is the one. It tested out fine but you just can't take it apart.
My problem was solved by a gentleman at Delco Remy Technical Support
I sent him the info on my truck Generator: Delco Remy Generator # 1102749-1C29 installed in my 1946 Chevy Truck. From research on the internet this Generator was parried with a Delco Remy Regulator 1118201
Following is his response:
February 06, 2012
From my information 1118201 became obsolete in 1948 ( 6 volts N 34-36 amps). 1118201 was superseded by 1118301.
I found a NOS Delco Remy 1118301 on EBay.
Sometimes things work out!
Thanks for all your help.
Harold
dance
Harold
1108201 is the voltage regulator listed in the specifications manual (at the link above).
Here are older manuals for both series of voltage regulators:
200 series manual
300 series manual
