0 members (),
91
Mod | | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Hi all, I have 58, 3600 with a 235. I have 2 questions. 1 I have an oil bath air filter. The top part is a self contained unit that does not come apart. The filter part looks like it has fibreglass threads inside. I don't know how long this has been in there so I dont know how dirty it is but I would like to give it a clean. What should I use to clean this? Question 2. I have a steal canister oil filter. What can I use to clean this as well Thanks Rick
Rick 58 3600 4 on the floor
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Any cleaning solvent to clean oil bath air cleaner or by-pass fuel filter parts. I use kerosene or diesel fuel. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Rick, are you sure it doesn't come apart? Mine is similar, it's a tight fit but mine came apart. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Are the chevy's different than the GMC's? here's a thread from a few days ago with some pic's of a GMC's set up. GMC air cleaner thread
| | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | I am fairly certain it does not come apart. The top comes off the bottom, but the top is 2 pieces but the metal has been curled around the edge so it cant come apart without me getting a screwdriver and pliers and mangling it all up
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | right Rick, the Chev oil bath air filter doesn't come apart, need to do as Tim suggests, just slosh it about thoroughly and drain/shake it dry-ish
Bill | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Thanks Tim for the manual
