| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 257 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 257 | Hi. I am hoping to get my 235 into my '59 this weekend. This is probably a silly question. Should I drain the oil from the engine when I install it because of the extreme angle I have to put it at when getting it into the engine compartment. I was worried about all that oil hanging out in the back of the engine and maybe seeping out through the rear flange. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | If it leaks then it will leak when it is running. If it is properly sealed then you shouldn't leak any oil. | | | | | Joined: Jul 2011 Posts: 257 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 257 | I'll leave it in then, thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I believe the flywheel bolts are wet on that engine. If the flywheel is not on the oil will run out the bolt holes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2011 Posts: 257 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 257 | I believe the flywheel bolts are wet on that engine. If the flywheel is not on the oil will run out the bolt holes. The flywheel is installed and I used the recommended Permatex on the bolts to boot | | |
