4 members (Gdads51, carbking, David Bush, 52Carl), 82 guests, and 9 robots.
Topics128,078
Posts1,056,031
Members48,433
#818935 01/23/2012 4:05 PM
Is there a difference between 12 bolt car and truck rear ends? I have a new complete 4:56 set up for a chevelle, will it fit my 66 truck 12 bolt? truck now has open 3:73headscratch
truck is diff from car, IIRC.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
the car ring & pinion can be installed in the truck rears. Ive did it.
Summit Racing lists them different, but I don't know what the difference is.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
There are also different size carriers for the 12 bolt. One excepts shorter gears and one excepts taller gears
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
ring gear sizes there are 8 and 8 1/2" sizes
Yes the carriers are different the 3 series carriers will accept ratios from 308 to 390. the four series from 410 to 488. you can use a spacer to install 4 series gears on three series carriers. You gotta know what your doing to set up a rear end. If you dont get it right it will sound like a siren and wear out quickly.
there is a difference in the carrier bearing size to. you can go onto a differential web site a look. there is more of a difference than just the gears. there are different carriers 1,2,3 for different gear ratios also.
Those are 10 bolts. The 12 bolt is an 8 7/8".
Bill Burmeister
GM 12-Bolt
Two versions of the GM 12-bolt exist but have nothing more than the bolt count in common. One is a car version with a grooved cover plate, while the truck-version cover plate is raised. The 12-bolt is integral and semifloating, but isn't a big step up from the 8-1/2-inch 10-bolt because the axleshafts and housings are very similar. A drawback to both the 10- and 12-bolt axles is that the axleshafts are retained by C-clips, which, if broken, can be a serious hazard.
Applications: '64-'82 K10/K20 and Blazer
Ring-gear diameter: 8.875 in
Pinion-gear diameter/splines: 1.438/30 splines
Available gearsets: 3.07, 3.42, 3.73, 4.10, 4.56, 4.88, 5.13, and 5.38
roofus #821899 02/01/2012 5:22 PM
Also in 3.90:1, 4.11:1 according to the 63 assembly book
