9 members (cmayna, Rusty Rod, TUTS 59, Rusty Heaps, 49choptop, treegrower, Wickedbass, UtahYork, Gray_Ghost),
108
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,067 Posts1,055,877 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 4 New Guy | | New Guy Joined: Dec 2011 Posts: 4 | Is there a difference between 12 bolt car and truck rear ends? I have a new complete 4:56 set up for a chevelle, will it fit my 66 truck 12 bolt? truck now has open 3:73  | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | truck is diff from car, IIRC. | | | | | Joined: Mar 2008 Posts: 55 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 55 | the car ring & pinion can be installed in the truck rears. Ive did it. | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Summit Racing lists them different, but I don't know what the difference is.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | There are also different size carriers for the 12 bolt. One excepts shorter gears and one excepts taller gears | | | | | Joined: May 2009 Posts: 47 New Guy | | New Guy Joined: May 2009 Posts: 47 | ring gear sizes there are 8 and 8 1/2" sizes | | | | | Joined: Mar 2008 Posts: 55 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 55 | Yes the carriers are different the 3 series carriers will accept ratios from 308 to 390. the four series from 410 to 488. you can use a spacer to install 4 series gears on three series carriers. You gotta know what your doing to set up a rear end. If you dont get it right it will sound like a siren and wear out quickly. | | | | | Joined: Apr 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 47 | there is a difference in the carrier bearing size to. you can go onto a differential web site a look. there is more of a difference than just the gears. there are different carriers 1,2,3 for different gear ratios also. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | ring gear sizes there are 8 and 8 1/2" sizes Those are 10 bolts. The 12 bolt is an 8 7/8".
Bill Burmeister | | | | | Joined: Apr 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 47 | GM 12-Bolt Two versions of the GM 12-bolt exist but have nothing more than the bolt count in common. One is a car version with a grooved cover plate, while the truck-version cover plate is raised. The 12-bolt is integral and semifloating, but isn't a big step up from the 8-1/2-inch 10-bolt because the axleshafts and housings are very similar. A drawback to both the 10- and 12-bolt axles is that the axleshafts are retained by C-clips, which, if broken, can be a serious hazard. Applications: '64-'82 K10/K20 and Blazer Ring-gear diameter: 8.875 in Pinion-gear diameter/splines: 1.438/30 splines Available gearsets: 3.07, 3.42, 3.73, 4.10, 4.56, 4.88, 5.13, and 5.38
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Also in 3.90:1, 4.11:1 according to the 63 assembly book | | |
