5 members (Stovebolt48, 78buckshot, Ponchogl, Shardean, dt235sd), 79 guests, and 3 robots.
Topics128,021
Posts1,055,349
Members48,420
#821544 01/31/2012 5:51 PM
what is the best way to replace cab corners on a 1950 chevy 3100?
Thomas
tbj188 #821558 01/31/2012 6:26 PM
Getting someone else to do it for free eeeek
otherwise MPandC posted this yesterday here Welding joints and it should answer most of your questions.
Give me ambiguity
or give me something else
CASO #821592 01/31/2012 8:17 PM
I have used these outer cab corners with success. The angles are pretty good. There is no weep hole (as was in the original cab corner).
tclederman #821599 01/31/2012 8:55 PM
I used those as well, and no complaint. I did only use the bottom half on my corner since it wasn't to bad and then was able to use the remaining top half for the rust pocket I had just forward of the door. took a bit of shaping but the curve was actually very close...fyi
Give me ambiguity
tbj188 #821602 01/31/2012 8:57 PM
DADS50 #821707 02/01/2012 1:21 AM
1 Offline
Ive got an extra cab that is junk and am going to try to cut the top cab corners and shape them to try and make something close enough to the lower corners.if on mock up it doesn't look quite right i'll buy them from classic parts.
Yea I think I will probably go with the corners from classic parts my self...all I need is a welder..lol
tbj188 #822581 02/03/2012 6:55 PM
Here is a picture link to how I did mine (tig welded).
Just click through the next few after this one.
http://community.webshots.com/photo/2265704470102454676pTFtwj
Welding finished:
http://community.webshots.com/photo/2075447450102454676bJSlPV
