| | | Forums66 Topics128,149 Posts1,056,817 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 123 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 123 | I have a 1958-62 [3764476] 235 block with pistons stamped .040 . I bought a new set of rings (supposedly .040 over) and they are small. end gap 3/16" when put into cylinder. Aluminum pistons. New rings are not as wide as old rings. Any ideas?
Joe A. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy joe apple, welcome, it sounds like you have been supplied the wrong parts, either they were packaged incorrectly, or someone ordered the wrong parts, good luck sorting it out. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I second that. My new pistons for my 216 took thinner rings too. | | | | | Joined: Sep 2009 Posts: 123 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 123 | Looks like I was sold the wrong rings. I looked up the part number in a Grant brand piston ring catalog and it is listed for a different engine with smaller diameter cylinders. Thanks for the input. | | |
