| | | Forums66 Topics128,094 Posts1,056,048 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | I have a 53 with white crystal like substance in my gas tank. What caused that and how do I get rid of it? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The best thing to do with these trucks when the gas tank is dirty or rusty is to buy a new tank. They are reaonably priced for the popular models. Its not worth it to get stranded somewhere with a clogged up fuel system. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | dont know what the substance is but most radiator shops can clean and dip your tank and also check for leaks and weak spots.
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Not sure what would cause a white deposit. You might try tumbling some heavy nuts/bolts in the tank to knock the stuff loose. I've heard of folks using gravel and short lengths of chain as well. If that doesn't get it you'll probably have to do an acid clean and re-line it or replace it. Do a site search for tank cleaning. You'll find a LOT of threads on the subject.
| | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | I was told at the local FLAPS that the older Stabil product would cause those depoits with the new gas, I was advised to throw out the old stuff and use the new formula. I never saw it happen myself. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I second the new tank, unless yours is in really good shape it is usually cheaper and easier to get a new one. I harbor a thought of lining a brand new tank, next time I need one... | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | be careful of some of the linings they let go and cause alot of problems
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I'm planning to use my old tank, which is currently removed from the cab and is in pretty good shape. I plan on using Tiny's route of cleaning it up by throwing in a few short lengths of galvanized swingset chain that I happen to have, with some solvent. I'm pretty confident this will work for me. I'm not sure what the crystals are in your tank... sand comes to mind. Did it show up in your filter bowl? I would have to remove the tank and get that mess outa there. Jerry | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Your deposits are most likely lead oxide from the TEL that was used years ago. I agree with some of the others that putting in a new tank is the only way to go if you want a dependable trouble free fuel system for years to come. They may look like new outside but they go bad from the inside out and I’d stake my wife on it that if it’s a 50+ year old tank, its gonna be rusty inside.
They are surprisingly inexpensive, just make sure it comes from Specta a Canadian OEM manufacturer, that way you know it‘s going to be an exact replacement.
DG
Denny G Sandwich, IL
