4 members (TUTS 59, 55shaker, Wrenchman, Oswald), 55 guests, and 1 robot.
Topics128,089
Posts1,056,010
Members48,430
#820765 01/29/2012 1:40 PM
I have a 53 with white crystal like substance in my gas tank. What caused that and how do I get rid of it?
Riding in the Passing Lane
The best thing to do with these trucks when the gas tank is dirty or rusty is to buy a new tank. They are reaonably priced for the popular models. Its not worth it to get stranded somewhere with a clogged up fuel system.
1972 Chevy c10 Cheyenne Super
mo Offline
dont know what the substance is but most radiator shops can clean and dip your tank and also check for leaks and weak spots.
MO's 1951 chevy 3100 resto mod project
Ex Hall Monitor
Ex Hall Monitor
Not sure what would cause a white deposit. You might try tumbling some heavy nuts/bolts in the tank to knock the stuff loose. I've heard of folks using gravel and short lengths of chain as well. If that doesn't get it you'll probably have to do an acid clean and re-line it or replace it. Do a site search for tank cleaning. You'll find a LOT of threads on the subject.
I was told at the local FLAPS that the older Stabil product would cause those depoits with the new gas, I was advised to throw out the old stuff and use the new formula. I never saw it happen myself.
I second the new tank, unless yours is in really good shape it is usually cheaper and easier to get a new one. I harbor a thought of lining a brand new tank, next time I need one...
mo Offline
be careful of some of the linings they let go and cause alot of problems
mo #821184 01/30/2012 5:05 PM
I'm planning to use my old tank, which is currently removed from the cab and is in pretty good shape.
I plan on using Tiny's route of cleaning it up by throwing in a few short lengths of galvanized swingset chain that I happen to have, with some solvent. I'm pretty confident this will work for me.
I'm not sure what the crystals are in your tank... sand comes to mind. Did it show up in your filter bowl?
I would have to remove the tank and get that mess outa there.
Your deposits are most likely lead oxide from the TEL that was used years ago. I agree
with some of the others that putting in a new tank is the only way to go if you want a
dependable trouble free fuel system for years to come. They may look like new outside
but they go bad from the inside out and I’d stake my wife on it that if it’s a 50+ year old
tank, its gonna be rusty inside.
They are surprisingly inexpensive, just make sure it comes from Specta a Canadian OEM
manufacturer, that way you know it‘s going to be an exact replacement.
DG
Denny G
Sandwich, IL
