7 members (cmayna, dt235sd, baldeagle, 1955 1 Series, NJC, 2 invisible), 93 guests, and 6 robots.
Topics128,016
Posts1,055,337
Members48,419
#820567 01/28/2012 9:07 PM
Hi all, I have 58, 3600 with a 235. I have 2 questions. 1 I have an oil bath air filter. The top part is a self contained unit that does not come apart. The filter part looks like it has fibreglass threads inside. I don't know how long this has been in there so I dont know how dirty it is but I would like to give it a clean. What should I use to clean this? Question 2. I have a steal canister oil filter. What can I use to clean this as well
Thanks Rick
Rick
58 3600 4 on the floor
rickyt #820572 01/28/2012 9:22 PM
Any cleaning solvent to clean oil bath air cleaner or by-pass fuel filter parts. I use kerosene or diesel fuel.
tclederman #820587 01/28/2012 10:20 PM
Leo Offline
Moderator
Moderator
Rick, are you sure it doesn't come apart? Mine is similar, it's a tight fit but mine came apart.
Leo #820641 01/29/2012 2:03 AM
Are the chevy's different than the GMC's?
here's a thread from a few days ago with some pic's of a GMC's set up.
GMC air cleaner thread
Give me ambiguity
or give me something else
CASO #821705 02/01/2012 1:18 AM
I am fairly certain it does not come apart. The top comes off the bottom, but the top is 2 pieces but the metal has been curled around the edge so it cant come apart without me getting a screwdriver and pliers and mangling it all up
Rick
rickyt #821711 02/01/2012 1:28 AM
right Rick, the Chev oil bath air filter doesn't come apart, need to do as Tim suggests, just slosh it about thoroughly and drain/shake it dry-ish
tclederman #822365 02/03/2012 12:25 AM
Thanks Tim for the manual
Rick
