Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (rick46ia, TexasJim50, Steelonsteel, baldeagle, Rusty Rod, thekid1950), 59 guests, and 3 robots.
Topics128,006
Posts1,055,268
Members48,418
#819928 01/26/2012 5:22 PM
(`58 1/2 ton)
My door shell and skin are in usable shape but my hinge pockets are thrashed. Top one has stress cracks between the bolt holes that I might be able to get the welder into to repair. But the lower one looks like someone took an air chisel to it and the nut plate is gone. Is it possible to replace the lower structure without skinning the door?
1959 Shortbed stepside 1/2 ton project
[Linked Image from i236.photobucket.com]
olddaze #819931 01/26/2012 5:30 PM
olddaze #819937 01/26/2012 5:43 PM
fixing those mount points is tough, makes for real problems fitting the doors afterwards - cutting into the front edge of the door can be done to fix some pocket problems, but I'd be looking for a replacement door, you'd need one anyway to get the parts that are missing in the lower pocket and it looks like you'd have to cut/replace the inner skin as well
