6 members (Gdads51, Hotrod Lincoln, Steelonsteel, Otto Skorzeny, Wally / Montana, 32Fordpuchoptop), 66 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#81968 08/24/2007 8:01 PM
I have a problem, I need to know the diameter of the rear main seal on the crank. I have a leaky rear main that just won't go away, The crank is pitted in that area and just tears up main seals.. There is a bushing that can be fitted over the serface but I can't get the bushing unless I know the exact size of the seal journal.I can't measure mine without dropping the crank. 350 engine about 72.
anyone have a old crank laying aroung that you could measure?? HELP
#81969 08/24/2007 9:57 PM
i got 2.430 on two cranks here.
our garage is a non-profit organization
#81970 08/25/2007 12:52 AM
Thank you much, If anyone has a different answer please jump in here/
#81971 08/25/2007 4:06 AM
H Online: Content
How are you going to get a repair sleeve over the flywheel flange? The late-model crankshafts that use a 1-piece seal might work with a repair sleeve, but I just can't imagine how to make that repair work with an early style crank.
#81972 08/26/2007 1:38 PM
Yup, the repair sleeve is what I am trying to find the size for. I don't know what you are refering to "early" the engine probably is about a 72 era, book shows it a crate engine that covered 15 years.
#81973 08/26/2007 3:26 PM
H Online: Content
On the pre-1991 V-8's, the flange where the flywheel bolts is roughly rectangular, and MUCH bigger than the seal surface. In about 91 or so, Chevy went to a 1-piece seal similar to an oversized wheel bearing seal, in an alloy carrier that bolts to the back of the engine block. There's simply no way to get a repair sleeve onto the rear seal area of a pre-91 crank, unless it has a split in it, and the joint of the ring would destroy its usefulness as a smooth sealing surface. There is a "speedy sleeve" repair for harmonic balancers with wear grooves in them, but that's on the front of the engine, and has nothing to do with the crankshaft.
A good automotive machine shop could weld up a worn seal area, and regrind it smooth, but the cost would be approximately twice what a new Eagle crank would cost on Ebay.
#81974 08/27/2007 1:40 PM
Will take it back to the guy that charged me $200 to replace the seal(2 piece) If nothing can be done, I guess I will have to live with a leaker?? Thanks.
#81975 08/30/2007 1:42 AM
Why not weld it and regrind or you may be able to grind the flange off and install a 1 piece repair sleeve.Does your existing crank have a knurl ? You need a knurl either on the crank or the seal or both.If don't the seal has no direction to direct the oil.If you decide to purchase a sleeve contact me and I can put you in touch with a supplier Classic Sleeve.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
#81976 08/30/2007 3:07 AM
87 was the year of the crank change to the one-piece. The fella might have torn the seal or something, I would try another seal first.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#81977 08/30/2007 2:30 PM
Going to go back and try the old rope seal. The crank had been setting around for awhile and has rust pits on the sealing surface. I really hate to pull it out for a oil leak. Thanks for the good advice all especially Brian and fleetside, You have me rethinking the problem
