| | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 2 New Guy | | New Guy Joined: Dec 2011 Posts: 2 | I have a 51 3100 that I would like to remove vent windows from, and am wondering if I can remove vent windows and relace with full size glass with change of tracks and regulator. Can anyone advise whether this will work, or is it more complicated? | | | | | Joined: Apr 2002 Posts: 65 'Bolter | | 'Bolter Joined: Apr 2002 Posts: 65 | I agree, vent windows are cool. But if you don't want them, maybe replacing the doors would be easier. 1951 Chevy 3100 "Project for my Wife" - Jigsaw Puzzle 1969 Camaro SS350 convertible 1969 Camaro 327 convertible
| | | | | Joined: Dec 2011 Posts: 2 New Guy | | New Guy Joined: Dec 2011 Posts: 2 | It appears to me that the doors are the same with a different track rail, and regulator however, I am not sure if that is a fact and would appreciate any input available. I can appreciate the the point of view however, in Phoenix summer driving with the window down, we don't worry about our hats blowing off, we worry about them catching flame | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | would like to do the same to my 51 also. two reasons 1 to get a little more arm room and 2 dont want to spend 300 a side for new wing windows. know it can be done but dont know whats involved.
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Guys, I"ve read about this many many times and I've only read of a very few that have been happy doing the switch. While there are a vendor or two out there that sells a kit to convert them most everyone that I've read about says they wish they would have just switched out the doors.
Perhaps you should offer to swap with someone who has big windows but wants the vent window. Ya'll could swap.
What ever you do keep us posted...and good luck. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Do the 50 doors have the same latch set up as the 51? Would the 47-49 doors with the different latch set-up work on the his truck?
He may have to be selective on doors
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | the earlier years have a different set up but as long as you use the correct striker plate with the same year door latch you should be fine....I ran into this when the panel I purchased had a 50 door latch and striker plate on the passenger side. When I put the correct 52 door on it I had to change the striker plate to. | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | the problem with switching to the big window is if you switch doors you have the fridge stye door handle also. i certainly like the push button handle better but also like the big window. i wanted to switch the handles already so i am thinking 52 doors with big windows. what do you think? MO
| | | | | Joined: Jan 2009 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 106 | Thought I would add to the discussion of vent windows but it may not matter if you don't want vent windows for appearance reasons. The function of vent windows can be improved greatly by using the clip on Brezees on the vent windows. The Breezees direct much of the incomming air downward and cool the legs and feet in hot weather. When driving at speed, adjusting the postions of the vent windows with the side windows rolled down allows good ventilation of the cab and deflects wind outward so it doesn't cause all the turbulence you get without a vent window. When the temperature gets over 100 degrees, I wet a kerchief with a bottle of water and wet down my arms and legs. It is amazing how well the evaporation cools the body. I have driven the desert at 110 degrees and was very comfortable using air circulation and a wet rag. Happy to say the temperature guage for the 235 never goes above 3/4 hot.
Stovebolts are good for the heart
