2 members (Hotrod Lincoln, homer52), 97 guests, and 1 robot.
Topics128,126
Posts1,056,355
Members48,441
I am installing all new wheel cylinders and Master cylinder this weekend.
Is there any information on Torque Specs for mounting Wheel cylinder to backing plate and on the Master cylinder to frame?
Riding in the Passing Lane
I don,t believe there are any specks for those specific items but you might find specks for bolt sizes. If you have been turning wrenches very long you develop a feel for it. Make sure you have good lock washers & replace any fasteners that are corroded or damaged. If you are concerned you can put a little lock tight on them.
1972 Chevy c10 Cheyenne Super
Thanks Wrenchbender RET,
I guess the feel torque will have to do
I was hoping there was something listed out there somewhere for a 1959 chevy 1/2 ton truck
I looked thru shop manuel and assembly manuel only to find engine torque specs.
tighter than heck an 2 more turns does not apply in this situation..once ya got em tight that is enough ..
1952 Chevy Shortbed
Photos in Photobucket
