| | | Forums66 Topics128,060 Posts1,055,833 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Does anyone sell the hoses where they are the two different sizes?
Thank you
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | negatory, get reducer fittings at a plumbing store
Bill | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Anybody had good luck with one of the vendors defroster hoses? There seems to be a bunch of them and in different types of materials.
TIA
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | shop local - measure the size/length needed and check your FLAPS
Bill | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I haven't seen anyone that sells two diameters of hoses in one pack.
I've had cloth defroster hoses from Jim Carter, The Truck Shop, and Chevs of the 40's. They are all pretty much the same, just different ID ... 1-3/4" and 2". The reason that I had so many is that I bought the wrong diameter. I don't have the hoses clamped or taped to the outlets and vents. They are holding OK.
My truck had plastic hoses on it when I bought it. They were held in place with duct tape, so I don't know if they slipped off easily, or if the tape was there for insurance.
On my '54 Fresh Air heater, both legs of the "Y" outlet on the heater case are 1-3/4" OD. The passenger defroster vent is 1-3/4" OD. But the drivers defroster vent is 2" OD. I have a rubber collar for one leg of the 1-3/4" OD Y vent so that I can slip a 2" ID hose over it to supply the 2" OD driver vent.
Otherwise, a 1-3/4" ID hose will fit INSIDE the 2" OD drivers vent and hold pretty well.
The '51 and '54 Accessories Installation Manuals show the rubber collars on various ends of the hose. Be sure to measure your vents and heater outlets.
(Lotta OD's and ID's in my post!)
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I'm confused. Are you asking about heater hose that runs from the water pump to the heater? The 90° elbow hose inside the heater from the core to the heater control valve? Or the duct hose that runs from the heater box to the plenum at the windshield defroster? - For the first, what Bill said - For the second, you can find it at a FLAPS or here at American Classic Truck Parts. They also have adapters for 2" hose to be used with a 1-3/4" outlet. - For the third, I got mine at Old Air Products but the ACTP link I show above also has them. Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I cannot find the thread discussing where one is larger than the other and the different sizes. I assume that I have a 53 heater that gets its intake from the side of the cab, has two different size hoses up to the defroster vents, and a cable from the left side of the driver to the heater box.
I just want to make sure the hose kit Tim notes is the right one.
Thanks again
