2 members (baldeagle, Shardean), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#818792 01/23/2012 1:59 AM
I've found a very nice 54 and reached an agreement with the owner. Truck is local, as is owner. Title is clean but the VIN doesn't seem right. VIN is listed as 0890243F54X. As always any help is appreciated.
that'd probably be the original engine number, which is what most areas used for registration back before the door tag serial number 'vin' became the govt mandated many digit VIN
Flxible #818799 01/23/2012 2:14 AM
Thanks Bill. I appreciate your reply. Unfortunately door tag is long gone.
The number you list should be stamped on the engine aft of the distributor.
Cletis #818806 01/23/2012 2:39 AM
http://www.gmheritagecenter.com/gm-heritage-archive/docs/Chevrolet-Trucks/1954-Chevrolet-Truck.pdf
It looks to me like the engine number for a 235 thriftmaster made for 54 in the Flint engine plant. If I am wrong, someone will correct me.
Greg_H #818838 01/23/2012 4:08 AM
As usual, Greg is correct: 1954 truck 235 Thriftmaster engine, 3100 1/2 ton series, assembled in Flint, MI
I agree with the others: check the engine number. If same as title - no problem that I see. If not, still not the end the world. Work with the seller to correct the problem with the paperwork. Florida probably has a way to fix that.
Good luck.
Professional Novice
Frank50 #819739 01/26/2012 1:26 AM
Scrub the frame on the drivers side between the firewall and radiator support and you may find the plant code and serial number. If you do not and you buy the truck purchase a number/ letter stamp kit like they sell at harbor freight and stamp the number on the frame.
dwragon #819756 01/26/2012 2:10 AM
Thanks to all. I appreciate the input. Will check it out this weekend.
dwragon #819758 01/26/2012 2:12 AM
On a USA 1954 Chevrolet truck?
dwragon #819762 01/26/2012 2:21 AM
You will find no numbers like that on a 1954 Chevrolet truck.
Furthermore, if the engine number does not match the title that needs to be corrected through proper channels. Stamping the number from the title onto the frame is asking for trouble.
Cletis #819908 01/26/2012 3:41 PM
My 54 has the vin on the door jamb. I know these VIN plates can often get lost in a restoration. Especially if someone is swapping cabs, replacing cowls, etc... Using the engine number has always seemed very unreliable, for the same reasons. If you have a title, I'd live with it.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
maybe not from one from NY, but yes on one from Fl or the south.
