7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible), 88 guests, and 1 robot.
Topics128,074
Posts1,055,910
Members48,429
#81861 08/22/2007 8:25 PM
OK - Time for new plugs, points, condensor, rotor and cap. All good except for the plugs. My old ACDelco 45's are no longer available - only ACDelco R-45's. My original manual says to use non resistor plugs. What would be the difference? I have no radio in the truck. Do resistor plugs offer a suppressed spark? Can't find anything in the search archives to answer this. BW
#81862 08/22/2007 8:39 PM
I've been advised to use non-resistor plugs too but I don't know the reason. After AC Delco went down the tubes, I ended up trying NGK B6S plugs as a substitute. They seem to be working well (in my 235).
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#81863 08/22/2007 8:52 PM
The R-45's will work fine. The only difference is the current flow in the secondary wiring, and there's less of a tendency to burn distributor cap contacts, rotor tips, etc. with the resistor plugs. At one time, there was a problem with using a resistor-type plug along with GM resistor wire, called "TVRS" wire, but the advice changed in the mid-70's at the GM training centers, and we were told to use resistor wires and resistor plugs together. As long as the resistance of a plug wire does not exceed 1,000 ohms per inch, the resistor plugs will work as well as, or better than the original types.
