6 members (Ponchogl, 48ed56pam, Bill Marlow, Hanks custodian, frogfarmer, 2-Ton), 246 guests, and 0 robots.
Topics128,081
Posts1,056,071
Members48,434
#818460 01/22/2012 12:07 AM
Hi all, I am new to this forum and starting on a project that I have always wanted to do. I have a 66 c10 with a 230 cid engine and 3 speed transmission. Would it be better to remove the transmission alone with the engine or take the motor out separately? I have to rebuild both or just swap them out.
check out tec tips
three spd trans are easy to re and re. drop it and take the eng out by itself. just easier and then you don't have to worry about gear oil running out the back of the trans( you can always drain it first i know). just unbolt it from the bellhousing and just reverse that when you put it back. I can never understand why people take the bellhousing off to take the trans out
ron
thanks for the advice.
thanks for the advice thats kinda what i was thinking just was not sure what would be easier.
