0 members (), 74 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#818131 01/20/2012 9:09 PM
I'm pretty low tech on stuff electrical, but how can one check with a volt/ohm meter these old T3 headlight bulbs to determime if the bulb is good or bad? The three tabs on the rear are low beam, high beam and ground. What resistance readings should I see for a good bulb? They seem dim, however it may be something else besides other than the bulb. Just trying to eliminate the bulb as the problem. Any suggestions?
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
IMO, it's easier to just use a battery.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Maybe a little late but I know you shouldn't use a 12v charger.
The only resitance reading that would tell the story is if it is infinite meaning open or burned out.
1951 1 Ton Completed
