| | | Forums66 Topics128,052 Posts1,055,773 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | I'm pretty low tech on stuff electrical, but how can one check with a volt/ohm meter these old T3 headlight bulbs to determime if the bulb is good or bad? The three tabs on the rear are low beam, high beam and ground. What resistance readings should I see for a good bulb? They seem dim, however it may be something else besides other than the bulb. Just trying to eliminate the bulb as the problem. Any suggestions?
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | IMO, it's easier to just use a battery. | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Maybe a little late but I know you shouldn't use a 12v charger. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The only resitance reading that would tell the story is if it is infinite meaning open or burned out. | | |
