| | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Hi I have 1958 long box. If I go under my truck and grab the bar that runs from 1 tie rod end to the other, I can turn that rod a good half of an inch front and back. Is that normal? Should there be so much play in this rod Thanks Rick
Rick 58 3600 4 on the floor
| | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | That depends.
Crawl under the truck and turn the rod again. If the 1/2 of rotation is the end rotating on the ball of the steering arm, that is normal. If it is actually unscrewing then the bolts need tightened after the alignment is correct.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | The ball stays still but the rod and ends can move forward or back. Nothing is coming unscrewed. I was just worried this bagginess might make the end pop off the ball. Rick
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That is normal. With the weight off the front axle grab the right front horozontily. Push & pull. If there is any play get someone to do it for you & see if the play is in the tie rod ends. There should be none. Grab the tie rod ends & pull up & down. There should be no play there either. If thats OK then you have nothing to worry about as far as tie rod ends are concerned. Its a good idea to change them over to the new style if you want to work on something & spend some money. Other wise they will be OK. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Thanks guys, did all of the above and everything seems tight. Thanks Rick
