6 members (homer52, TrknGMC, Ponchogl, klhansen, Robert Crandall, Hotrod Lincoln), 37 guests, and 3 robots.
Topics128,023
Posts1,055,371
Members48,420
#817926 01/20/2012 1:16 AM
Hi I have 1958 long box. If I go under my truck and grab the bar that runs from 1 tie rod end to the other, I can turn that rod a good half of an inch front and back. Is that normal? Should there be so much play in this rod
Thanks Rick
Rick
58 3600 4 on the floor
rickyt #817934 01/20/2012 1:30 AM
ODSS Lawman
ODSS Lawman
That depends.
Crawl under the truck and turn the rod again. If the 1/2 of rotation is the end rotating on the ball of the steering arm, that is normal. If it is actually unscrewing then the bolts need tightened after the alignment is correct.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #818128 01/20/2012 9:05 PM
The ball stays still but the rod and ends can move forward or back. Nothing is coming unscrewed. I was just worried this bagginess might make the end pop off the ball.
Rick
Rick
rickyt #818146 01/20/2012 10:09 PM
Riding in the Passing Lane
That is normal. With the weight off the front axle grab the right front horozontily. Push & pull. If there is any play get someone to do it for you & see if the play is in the tie rod ends. There should be none. Grab the tie rod ends & pull up & down. There should be no play there either. If thats OK then you have nothing to worry about as far as tie rod ends are concerned. Its a good idea to change them over to the new style if you want to work on something & spend some money. Other wise they will be OK.
1972 Chevy c10 Cheyenne Super
Thanks guys, did all of the above and everything seems tight. Thanks
Rick
Rick
