1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#817244 01/18/2012 12:28 AM
I'm looking at a 54 3100 with 3 on the tree. I got the shifter jammed a few times between 1st and 2nd on the test drive. As long as you shift in an H pattern (90 degrees)it's OK but if you cut corners and shift in more of an angle it jams. It's okay between R & 1st as well as 2nd to 3rd. Problem is only between 1st and 2nd. Anyone know what's going on and what the fix is? Any and all help is appreciated. Thanks.
a very common problem - too much of that "cutting the corners" - you need to open up the box on the lower column, clean it out well, notice the way it's supposed to work, examine the positioning of the forks [adjusted with the end fitting on the rods to the trans], see if the corners of the forks or the pawl are too rounded off, fix as needed, regrease and reassemble
Flxible #817912 01/20/2012 12:28 AM
Thanks red58. Just wondering what the fix would be. I imagine the corners are rounded off. If so what is best way to repair? Anyone sell parts for this? I'd just like to have a better idea of what I'm getting into before I start. Any other hints, tips or info is most appreciated!!!
no parts available, but some vendors carry rebuilt replacements and if the fork corners are really bad they can be built back with weld .... might not take more than cleaning and adjusting the arm connectors adjacent to the box - pic here and the ones following, pretty simple and straight forward
Thanks again. Great pics!!!!! Sure makes things clearer. I appreciate all the help.
