| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | What is the best way to remove the ignition switch from the dash? I have the replacement, but would like to know the best way to remove the nut to get the switch out of the dash.
Thanks in advance for your help! MK
Mike Kelley 1966 Chevy C10 SWB - 250 L6/S10 T5 2002 Chevy Ext 1500 4x4
Http://myol66.wordpress.com
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | There is a tool that will fit into the three slots on the front of the ignition bezel. I couldnt locate a tool, but used a really thin piece of steel (left over from body work), I bent it to catch two of the 3 slots and the bezel came off real easy. The ignition switch will drop out through the back. Did the opposite to reinstall. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I made one from a cheap imported 3/8" drive socket of the same diameter of the ignition switch bezel nut. Sit the socket on top of the bezel nut, mark the locations of the slots on the bezel nut on the socket. With a cutting wheel, remove the material around the perimeter of the socket, leaving only the knubs at the locations of the slots in the bezel nut...viola, you have a ignition switch bezel nut removal tool. | | | | | Joined: Jun 2006 Posts: 10 New Guy | | New Guy Joined: Jun 2006 Posts: 10 | Everyone is assuming you have removed the tumbler from the switch already...... That takes a real expensive paper clip!! | | |
