| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81735 08/20/2007 9:10 PM | Joined: Dec 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 42 | I've read on the CPP tech articles that the maximum tire size is 7 inches when converting over to a late model chevy box. My question is , will the Toyota steering box fit any better. Also need source for 235 mounting brackets and pulleys. Thanks | | |
#81736 08/21/2007 1:23 AM | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Robert, I have the Toyota box on my 56 3100 and it does not have any clearance problems as it mounts in the same location as the stock box. You still have to take into account your wheel backspace as the tire could could hit the drag link. I used a wheel with 3 1/2" backspace, you may get away with 4" but I would set everything up before buying new wheels. The 235 brackets & pulleys are a problem as no one seems to make a kit. Fred
