0 members (), 329 guests, and 3 robots.
Topics128,168
Posts1,057,100
Members48,463
To begin, I am new here and to the world of panel trucks. I am mechanically inclined and work on older British bikes. The truck in question is a 1952 Carryall (manuals and parts book on the way). As off now, neither the gas guage nor speedo are working. Are these common issues? Any advice on how to tackle these problems? Any help is appreciated.
Before you delve into the gas gauge, check the sender. Mine had pin holes under where the rod wrapped around the float. Drained it, soldered it and now it's fine. The gauge can be replaced, individually or all 4, but be careful if you remove and replace the individual gauge. If it moves a bit as you tighten it into the case it can short out and melt your wiring.... Yes, I've done it.
the electrical gauges, (gas, and amp) in my 53 have little slots/indents that line up with little tabs that stick out from the gauge panel thingy (I don't know what its called, the part the gauges fasten too any way) to keep it from contact with the panel so it shouldn't be able to short out, I'm not sure about any other truck though.
