Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Steelonsteel, TUTS 59), 41 guests, and 8 robots.
Topics128,010
Posts1,055,299
Members48,419
#809828 12/24/2011 12:12 AM
Ok so the first project I did on my truck was the brake system and they have been great for 4 years. The other day I took the truck for a ride and the brakes were soft. I checked the fluid and there was none in the master....
There appears to be a very tiny leak in the front of the master. Not even enough to drip on the floor (I have never seen any evidence of leaking until I peel back the rubber boot). When depressing the brake there is a tiny weep at the front of the master.
All brake parts are new (4 years ago)
Should I have been checking the brake fluid routinely? Is is usual to have this type of leak?
Rich
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
I check in the spring when I take the truck out frist time and every 6 to 8 weeks after that tell winter,but I do that to my other truck and my wifes car also.Best be safe.
Pete
These old trucks ain't got very good brakes compared to newer vehicles. Keep 'em adjusted and check that master cylinder often. Your truck will thank you !!
yes you should be checking it routinely, and checking adjustment as well, and now that you've found the master reservoir empty it's time to bleed the system, these old systems are vented to the air - unchecked for 4 years, the fluid loss is as likely to have been from evaporation as from a weep that's so minor it isn't evident outside the rubber boot
Thanks Guys...I will check monthly from now on.
I will need to bleed and adjust before I take her out of storage in the spring.
1953 3/4-Ton Chevy
More pix
RB53
Just a little tip. I have rebuilt hundreds of brake cyls with good results,but in working on firetrucks I had poor results in rebuilding them.My thoughts are when you over bore the cyl and it sets for long periods the pressure drops off and allows the cup to relax thus it leaks. To verify this I would go by the fire house every week or so and pump the brakes. As long as I did this they would not leak.Just more stuff based on real world expierence.
If you have fluid leaking out the boot, the scraper piston that retains the fluid is leaking. You need to pull the master and redo it. You can keep adding fluid but you may pay for it some day.
1951 1 Ton Completed
yes without a doubt check all the fluids in any machine routinely. That is one of the ten commandments of machinery maintenance (don't ask me what the other 9 are)
just one quick question; does anybody change brake fluid anymore??? after months/years of absorbing water it turns to crap......kev
