0 members (), 40 guests, and 2 robots.
Topics128,072
Posts1,055,906
Members48,429
#816449 01/15/2012 9:57 AM
mo
Offline
has anybody ever filled in all the extra holes. ive been filling in extra holes but now cant find what some of them are for. does anybody have or know of a diagram that says what all the holes are for. would like to double check my work. pretty sure i am good from the bed forward but want to double check the back half.
MO's 1951 chevy 3100 resto mod project
mo #816487 01/15/2012 3:20 PM
Why?
mo #816510 01/15/2012 4:39 PM
H Online: Content
Welding on a frame can have serious consequences- - - -stress points, weak spots, etc. If you just want a smooth-looking frame, try using "Kitty Hair" Bondo with the fiberglass strand reinforcement to fill the holes, then sand and paint.
Grigg #816511 01/15/2012 4:39 PM
Originally Posted by Grigg
Why?
"new to stovebolt. rodding out a 51 chevy 3100. will have a clean and smooth boxed frame. mustand ii front end tci rear leaf with narrowed 9 inch ford posi with 370 gears. 350 4 bolt hopefully around 450hp and a 700r4. discs all around to stop. dont know which color yet but it will be shiny and deep with some minimal chrome. thinking a second series dash with some tricked out features such as vacuum doors over radio and dash knobs. just looking for a very clean show and drive truck. thinking it will take ten years to build but i think it will be worth it."
mo
Offline
i cant use kitty hair or fiberglass because of the powder coating of the frame when done. i do have what is called lab metal but i dont know if that will stand up enough to fill holes. also when boxing in the frame their will be less than 3 pieces per side so not worried about the frame when done it will be plenty strong. just need to know which holes are for the bed mounting and the rear fender strut rod
mo #816574 01/15/2012 9:04 PM
Mo, I suggest you get an assembly manual and take a good look at it. Look at the diagram for your model. It will tell you a lot of what you need to know....the online shop manuals may have a good pic but not sure of that.
Mo,
Post a few photos of the frame, showing the holes. If you can annotate the holes with numbers, maybe people would be able to tell you what holes are used on a standard pickup.
State the year, size, and model truck.
mo
Offline
ive got the assembly manual, theres a picture of the frame with all the holes and measurements but they dont state what there for. actually blew it up and laminated it so it wont get ruined working in the shop(cost 3.00). also looked through every page in the assembly manual and cant find these holes other than cutaway pictures. i know the front bed mount holes but i need the back two mount holes on each side. then there is a strut rod that supports the rear fender someplace behind the wheel. so these 6 holes are the ones i need locations for. if anybody could look on their truck and let me know that would be great. thanks in advance
mo #816602 01/15/2012 11:58 PM
mo
Offline
we found the bed mount holes we think. do the second or middle ones go thru both rails? then we think we found the back ones also. just need the fender support holes. if i cant figure it out might have to not box that far back or figure something else out. thinking plate in the inside so i can drill and tap them at time of assembly.
mo #817970 01/20/2012 4:04 AM
DADS50 #818010 01/20/2012 12:15 PM
mo
Offline
thank you for the picture now i can finish fillin the extra holes. that is exactly what i was looking for. i couldnt remember where that rod attached been a year since i took the bed off. thank you again
mo #818216 01/21/2012 2:29 AM
mo
Offline
in the garage again takin a break. any how i think i will make a diagram of what the needed holes are for on my 51 3100 shortbed so if any body else needs the info i will have it.
