| | | Forums66 Topics128,026 Posts1,055,406 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 12 New Guy | | New Guy Joined: Dec 2009 Posts: 12 | Changing points. The new set from NAPA came with an extra unattached curved silver metal spring. Old points didn't have this extra spring. Is it necessary?? Where would it go? Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is a set with one spring, I think. All the ones that I have used on 216/235/261 engines have a thin contact-spring and a thicker spring (two pieces) that went around it. It looks like one-piece contact/spring points-units are now available. Here's one with two "springs". Here is one for a 1959 235 at Rockauto.com. Can you post a photo of what you have? What is your NAPA part number? | | | | | Joined: Dec 2009 Posts: 12 New Guy | | New Guy Joined: Dec 2009 Posts: 12 | Thanks for the reply Gabster.The contact set base is just like the one you showed (which is like the one I took out) with one spring but it came with the extra spring to clip in like the second pic you showed. NAPA part # is CS763P Should both be used? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The spring spoons the brass strap. If you do not use the extra spring the brass strap will not put enough tension on the points and they will float.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | Like dave says the brass is just for elec contact the silver peice is the spring use both. | | |
