1 members (dt235sd),
307
7
Mod | | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | I have a few spare generators and would like to know what voltage they are. The one in my truck has 6V stamped into it. One of the spares has a part number, but is a different shape/different pulley. I do have one that matches my current generator, but it has no number and I can't find anywhere that it is stamped. Any way to tell what it is? | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | black tag 6 volt
red tag 12 volt | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Okay, so the one that has a tag on it is 6 volt. But the one that looks more like mine(right length and pulley) has nothing on it that I can see in the way of identification. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | If I remember correctly the 12v had plastic covered fields and the 6v were cloth covered. | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | Some of the auto stores have testers. Don't know whether they test generators. Might be worth a call. Also try a starter/alternator/generator repair shop, if you have one nearby. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Thanks, I didn't even think of that. | | |
