4 members (Peggy M, Otto Skorzeny, klhansen, farmallb), 107 guests, and 2 robots.
Topics128,041
Posts1,055,487
Members48,424
#815344 01/11/2012 4:25 AM
Trying to get cab off and need help! Any know how to get the Sterling wheel off! Please help!
3B Offline
Hy brickman, 40s aren't my specialty, but in most cases I've come across, remove the horn button, remove the horn contacts, remove the nut holding the steering wheel in position, now there might be threaded puller holes and there might not be I'm not sure, if there are threaded puller holes use those with some long bolts and a steering wheel puller to pull the steering wheel off of the steering shaft, if there aren't any threaded holes a jaw puller or some "J" bolts could be used, I'm sure if I'm all wet on this someone will be along with the correct procedure, hope that helps.
3B #815494 01/11/2012 7:21 PM
Big Bolt Forum Co-moderator
Hope you don't have to do this to your steering wheel:
http://www.pbase.com/czechman/image/104745452
(from Woody's slide show)
1948 Chevy 2-Ton
I don't know if your steering wheel has the threaded holes but the one on my 38 sedan doesn't. I used the same puller that I used on the damper except that I took three bolts and bent the shanks to form J hooks. I placed the hooks on the steering wheel spokes and used the puller to get if off.
1951 1 Ton Completed
Crusing in the Passing Lane
Make sure the nut is loose but NOT removed. Sit in the seat, grab the wheel, rock the wheel around by pulling on one side or another, warm day better, hopefully will eventually come loose w/o hitting chest(remember the loose nut!)
I don't see any nut on the wheel and the horn was a add on so no horn in center of wheel
I got it!!! I added some new pics too!!
Really is beginning to take shape and what a nice old truck.
Great job.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Or, like i did on my 59 vw bus, drill two holes in the hub and run a thread tap in them, use a steering wheel puller. Worked great. Now, if there is a next time,it will be much quicker and easier.
everybody is ignorant @ something.the more we work together, the less ignorance there is floating around
