2 members (Gray_Ghost, Joe W), 211 guests, and 2 robots.
Topics128,108
Posts1,056,231
Members48,436
#81523 09/07/2007 3:09 AM
Okay, I won the bid and this is the description of what I bought...
"operable Carter YF carb, removed from a running GMC 270ci engine."
I need to get this to work on my 261 and my rochester B will be consigned to target practice!!!!
My first question is... Will I need to change the jets or anything else to optimize this for my 261? I was thinking that the CFM for a 270 should be very close to that of a 261, but I know zero about carbs, so???? I am hoping all I will need to do is clean it and kit it. Let me know.
David
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless!
My 1962 Chevy C-30
#81524 09/07/2007 1:06 PM
Carburetion specialist
Oly - what is the carburetor identification number stamped on the center section? Should be either 3 or 4 digits, followed by the letter "S" as in (S)am.
Jon.
The Carburetor Shop
#81525 09/08/2007 12:11 AM
I see a 2207 inside a little rectangular box underneath a big 'X' but that is all I can make out. and I do not see an 'S' after the number.
My 1962 Chevy C-30
#81526 09/08/2007 5:59 PM
Oly - ALL original equipment Carter YF carbs were stamped. A few early aftermarket YF's (mostly for the 216 and 235 Chevrolet) were not stamped, and identified by tag only.
G.M.C. NEVER used a Carter YF on the 270. Starting about 1966, G.M.C. did use a YF on some 250's and 292's.
Without knowing exactly what you have, I am guessing; but you may have one of the early aftermarket units which are unsuitable for either a G.M.C. 270 OR a Chevrolet 261.
Jon.
The Carburetor Shop
#81527 09/10/2007 7:00 PM
I am just going by the pic on ebay...I have not actually received the carb yet. Hope to get it today.
My 1962 Chevy C-30
#81528 09/10/2007 7:12 PM
Oly - when you get the carb, look for the stamped number on the center section. Hopefully, it will be there, and one you can use.
Jon.
The Carburetor Shop
#81529 09/13/2007 1:26 AM
Hey Jon,
I got the carb and here are some pics of it.
http://viewmorepics.myspace.com/ind...mp;friendID=230390877&albumId=718354
There is a number followed by an 'S' It looks like 964S. Does that tell you anything?
My 1962 Chevy C-30
#81530 09/13/2007 1:33 AM
Oly - the 964s is a replacement for a Chevrolet 216. This carburetor should not be used on a 261 (unless you use 2 or more of them grin).
Jon.
The Carburetor Shop
#81531 09/13/2007 2:02 AM
Hey Jon,
How about a 3211? I am getting one of those in a few days...
My 1962 Chevy C-30
#81532 09/13/2007 12:53 PM
Carter YF carbs that are suitable (using only 1) for a 261:
4080
4085
4086
4339
4367
4368
4369
4370
4371
4372
4375
4376
4480
Jon.
The Carburetor Shop
