7 members (55shaker, Shade Baby, Bill Hanlon, Jon G, 78buckshot, TrknGMC, 1 invisible),
109
Mod | | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | what holds the "glass run channel" into place on the door frame? this is the "7" shaped part in the upper left inside the dashed box (coincidentally labled "7") of this page: glass run channel thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | in addition to it's natural tight fit in the vertical channel, originally there were some small sheet metal clips that stab into the back of it and wedge into it's track at the top of the door, not available repro that I've seen, you need to salvage them from your old felt run - also need to cut it to a very tight fit for length so it's wedged between the bottom end and the division post
Bill | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | once again - thank you Bill.. i don't have the old ones any more, so i'll have to make a clip or figure out something else. ever thought about adhesive? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | some weatherstrip glue should work, doesn't take much to hold them snug if they're not cut too short, the window wedges them in pretty well .... the clips are just a rectangular piece of light metal with a pointy triangle punched loose in the middle to stab into the felt
Bill | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | Thanks Bill - i will cut them to length carefully and probably add a dab of weatherstrip adhesive as you suggest | | |
