Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Phak1, Otto Skorzeny, Tinker5), 183 guests, and 5 robots.
Topics128,274
Posts1,058,436
Members48,490
what holds the "glass run channel" into place on the door frame?
this is the "7" shaped part in the upper left inside the dashed box (coincidentally labled "7") of this page:
glass run channel
thanks
in addition to it's natural tight fit in the vertical channel, originally there were some small sheet metal clips that stab into the back of it and wedge into it's track at the top of the door, not available repro that I've seen, you need to salvage them from your old felt run - also need to cut it to a very tight fit for length so it's wedged between the bottom end and the division post
once again - thank you Bill.. i don't have the old ones any more, so i'll have to make a clip or figure out something else. ever thought about adhesive?
some weatherstrip glue should work, doesn't take much to hold them snug if they're not cut too short, the window wedges them in pretty well .... the clips are just a rectangular piece of light metal with a pointy triangle punched loose in the middle to stab into the felt
Thanks Bill - i will cut them to length carefully and probably add a dab of weatherstrip adhesive as you suggest
