1 members (Steelonsteel), 125 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
#815105 01/10/2012 2:33 PM
a friend of mine that is a lumber cutter offered me enough oak from his private stash to build my bed (`58 short bed). Could someone measure up the dimensions of the two different sized boards?
[IMG]http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/bedwood-1.jpg[/IMG]
1959 Shortbed stepside 1/2 ton project
[Linked Image from i236.photobucket.com]
olddaze #815119 01/10/2012 3:28 PM
your diagrams aren't quite the right shape for the outside edge .... dimensions shown here: http://www.gmcpauls.com/47-72_BedWood_Info.htm , scroll down
Flxible #815141 01/10/2012 4:48 PM
Thanks, just what I needed! I didn't realize the side cut had that little "hook". Do the two outside boards have it too?
olddaze #815142 01/10/2012 4:56 PM
the edge rabbet is for the skids to sit in, allowing small movement from swelling/shrinking without pulling out from under the skid strip, the outside edge boards don't get any shaping where they mate with the flat flange of the box side
olddaze #815163 01/10/2012 6:21 PM
Here is a link to our tech article on making your own bed wood http://www.mar-k.com/bedwooddimensions.pdf. This should give you all the info you need to make a perfect fit wood bed--also has a drawing of the groove with exact dimensions. Good luck!
Mar-Ktech #815268 01/11/2012 12:10 AM
Thanks! You guys are my backup plan. I can build just about anything with some steel and a welder, but I'll admit when it comes to woodwork I've got two left thumbs.
