8 members (Otto Skorzeny, Steelonsteel, Gdads51, J Lucas, Peggy M, dt235sd, walter74, klhansen),
127
Mod | | | Forums66 Topics128,036 Posts1,055,454 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | your diagrams aren't quite the right shape for the outside edge .... dimensions shown here: http://www.gmcpauls.com/47-72_BedWood_Info.htm , scroll down Bill | | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | Thanks, just what I needed! I didn't realize the side cut had that little "hook". Do the two outside boards have it too?
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the edge rabbet is for the skids to sit in, allowing small movement from swelling/shrinking without pulling out from under the skid strip, the outside edge boards don't get any shaping where they mate with the flat flange of the box side
Bill | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | Here is a link to our tech article on making your own bed wood http://www.mar-k.com/bedwooddimensions.pdf. This should give you all the info you need to make a perfect fit wood bed--also has a drawing of the groove with exact dimensions. Good luck! | | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | Here is a link to our tech article on making your own bed wood http://www.mar-k.com/bedwooddimensions.pdf. This should give you all the info you need to make a perfect fit wood bed--also has a drawing of the groove with exact dimensions. Good luck! Thanks! You guys are my backup plan. I can build just about anything with some steel and a welder, but I'll admit when it comes to woodwork I've got two left thumbs.
