7 members (BCBill, Gdads51, Lightholder's Dad, joe apple, Hawkman, greenie-reddy, TUTS 59),
190
0
Mod | | | Forums66 Topics128,101 Posts1,056,176 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 11 New Guy | | New Guy Joined: Feb 2011 Posts: 11 | i have a hot rod air stardard elite 53-1000 3 vent with heat/cool/defrost vacuum system and i didnt get instructions. hot rod air closed a couple years ago and the i have spent hours looking on the internet with no luck. i know that vintage air and hot rod air are the same basic design. but the big difference is the wires are a totally different color and hot rod air has a third vacuum valve that vintage air doesnt. does anyone have instructions.mainly the wiring and vacuum part. | | | | | Joined: Jul 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 34 | Hello, I used the Hot Rod Air system in my 35 truck. I will see if I can ind the paper work? If I can, I will scan it and send you a copy.
Russ Sweet | | | | | Joined: Jul 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 34 | Hello, I used the Hot Rod Air system in my 35 truck. I will see if I can ind the paper work? If I can, I will scan it and send you a copy.
Russ Sweet | | |
