5 members (TUTS 59, bluechev, Guitplayer, Charles in CA, 1 invisible), 86 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#814512 01/08/2012 6:24 PM
you guys know if from the factory. the the 41-46 trucks front bumpers have a washer before the lock washer and nut. thanks katrina
I like fixing stuff.
katrina #814747 01/09/2012 1:19 PM
on mine it goes bolt,lock,flat
51 ashton #815059 01/10/2012 4:59 AM
I was taught and always (OK, maybe I fudge sometimes) put the flat washer first, and the lock washer directly behind the nut, as that is what you are trying to keep from turning! Also, when you remove it...and you will, it won't scar up your bumper (or whatever.) Good luck!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
40casey #815129 01/10/2012 4:13 PM
in our case the bolt is threaded into the front of the frame rails.
51 ashton #815138 01/10/2012 4:37 PM
For all my practical purposes, Flat, lock then nut.
