4 members (RoadsScholar, 55shaker, Ponchogl, warlock), 64 guests, and 1 robot.
Topics128,049
Posts1,055,629
#812161 01/01/2012 4:04 PM
Is there a pin that connects the 2 connected hood halves to the front hood ornament? The rolled ends of the hinges are too big for the back of the hood ornament. Thanks.
watsjoe #812219 01/01/2012 6:53 PM
Not sure what you mean by hood ornament. Can't say I've seen one for this style truck. The 1939 cars with split hoods show them though. Yes, there is a pin that connects the hood to the front divider/nose piece.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
641Workmaster #812229 01/01/2012 7:32 PM
Did you buy a new hinge piece, or ornament ? I had this issue with a hinge I got fron Chev's of the 40's. The original hinge has an extension front and rear that fits into the hole in the ornament, and sits on the concave recess at the firewall. The new one I got was way too large in diameter to fit at the ornament. The holes for bolting up the hood halves were also drilled wrong. Chev's of the 40's said this was first complaint they had gotten, but did not have an alternative / gave me a refund. I ended up using a small screwdriver tip for now until I can find the correct hinge
1940 Chevy KC 1/2-Ton
Britcon #814603 01/08/2012 11:52 PM
I’m not sure the ’41 had any kind of a hood ornament. Mine and the others I’ve seen just have a curved “bullnose" that sorta matched the shape of the center hinge and curves down to meet the top of the grill. At the hood end it is bolted to the top of the radiator support and at the bottom it is bolted to the upper grill. The front stub of the hood center hinge fits right inside of it.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Kip's41 #814683 01/09/2012 4:06 AM
There was no hood ornament on 41 to 46
Monroe McKill
