0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#813343 01/05/2012 1:33 AM
I got tired of the hood banging on my head so I installed a new pair of hood hinge springs from LMC. The hood still won't stay up without the trusty wood prop. What gives? Any suggestions?
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
Riding in the Passing Lane
Thats strange. Is the hood exrta heavy with undercoat?
1972 Chevy c10 Cheyenne Super
No undercoating. Nothing on or under the hood that shouldn't be there.
Oldbolter
your hinges have worn pins, a common problem with hood fitting and opening problems, the springs rarely are "bad"
EDIT: I just noticed that your truck is a '59. I believe that it has different hood springs that AD trucks. If so, disregard my answer below ...
The hood of my buddy's '53 F-100 panel requires a "wood prop", too. He believes that the hood spring were installed a half-turn too loose after the restoration. Don't know if that is right, or if it is applicable to your Chevy. The F-100 spring and the AD spring are similar. I think that his hood springs are new reproductions. He hasn't attemped a repair yet.
- Lonnie
My '54 3104
Thanks Bill, I hadn't considered the pins. You saved me from trying yet another set of springs. One more reason why the members of this forum are the best.
Oldbolter
Oldbolter, I had the same problem with my hood on my '59. Sent my hinges to Willie Wilson, does great work, cleans, blasts, repairs, will even powdercoat if you wish.
http://hoodhingerepair.com/
Darren
Darren,
Thanks for the link. I checked the web site and this looks like what I need.
Oldbolter
Are the springs for the 55 2nd to 57 different from the 58-59? If so, are the ones you have the wrong springs?
Just a thought
Dennis
Dennis,
Your post really got me to thinking - maybe I did put the wrong springs on it. So, I found the packaging material and checked: they are marked '58-'59. It looks like I'm back to rebulding or replacing the hinges.
Oldbolter
Sorry. I wished I could have helped
Dennis
