2 members (DHedrick, WarEagle1),
103
Mod | | | Forums66 Topics128,087 Posts1,056,375 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | so i started to install new bushings in the frame for the rear shackles. used a old pin to tap in with a hammer rather than tapping on the bushing. both rears went in about 95% of the way. So i was stumbled, heard try a vice, so i bought a vice, i think the darn vice would rather bend before those darn bushings with budge the 5% they need to go before i can install the new rear shackles....any ideas stovebolters??! | | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | I had same issue when I replaced mine. Take 'em back out and clean the hole with scotch brite pad or similar stuff. Also clean new bushing. Apply thin film of anti-seize to hole and bushing. Mash 'em back in. Check out tech tips on this - good info. Good luck! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do everything tcox suggests plus freeze the new bushing.
