9 members (Nhluvstruck, 32Fordpuchoptop, Bill Hanlon, DHedrick, Ponchogl, Southerntruck, Otto Skorzeny, 1955 1 Series, 1 invisible),
125
0
Mod | | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | Do I need to reduce the voltage to the starter when converting to a 12 volt system? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No.
However, use the 6v starter with a flywheel that came with a 6v truck (the 12v-truck flywheel had a different number of teeth, so the 12v starter had different style teeth).
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Do I need to reduce the voltage to the starter when converting to a 12 volt system? Nope, just don't grind the starter for long periods. If it takes more than 20 seconds or so to fire let the starter cool before trying again.
| | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | Thanks much for the help. | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | I'm not sure if my starter is any good. (Never started it since owning it) Can I hook jumper cables to it and see if it turns? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sure, just do it on the floor other wise it might jump off the bench. It's gonna arc so becarful it can burn the threads off the post. I would hook the pos to the nut on the post and touch the grouind cable to the housing last.
DG
Denny G Sandwich, IL
| | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Well, I took the starter to the second parts store that said they could not test it, so I hooked up some jumper cables to it in the driveway. As soon as the lever was pushed down the gear started spinning! | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | My 6-volt starter/12-volt system works so well, I just quickly tap the foot button, even when it's cold. Tromping it would be way too long.
I concentrate on getting my foot off it ASAP. It's really that good. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Wally: Your truck looks great. Don't see too many old flat beds around. I'm keeping the same look on my truck as well. I'll be doing the first start up soon hopefully. Just need to get a battery that fits in the box below the floor. I was wondering how I can get gas into the lines without cranking the motor over too much. I don't want to burn up the starter. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | My 6-volt starter/12-volt system works so well, I just quickly tap the foot button, even when it's cold. Tromping it would be way too long.
I concentrate on getting my foot off it ASAP. It's really that good. Wally, sounds good. A well-maintained 6v system starts very quickly; a 6v starter in a well-maintained 12v system starts even faster. On my 12v system with a 6v starter, one quick push and the engine starts. I chuckle and shake my head when someone posts about the foot-actuated starter and refers to it as a "stomp starter". If they have to stomp on it (6v or 12v), either they are in a bad mood or they need to fix something in their starter system. I've seen people inexplicably pushing and stomping with their whole weight and strength, thinking that will help out the starting system. Stomping on a foot starter is as useful as hitting the dashboard before turning the key in an ignition starter-switch. | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Wally:I was wondering how I can get gas into the lines without cranking the motor over too much. Loosen the bolts holding the fuel pump onto the engine a turn or so, and wobble the pump up and down a little. You'll pump gas without turning the engine that way. When you can work the throttle linkage and see gas squirt into the carb throat, you're good to go! Jerry
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Tim -
But "Stomp Starter" just sounds cool.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Could I turn the engine over by hand and get the fuel pumped up that way? | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I cheat, I use my brake bleeder (mightyvac) to suck fuel up to the carb. I fill the float bowl with gas (squirty ketchup bottle like at a diner). When the truck starts, the pump does the rest. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | When I was sealing my gas tank and had it out of the truck, I used a 6-gallon boat gas tank in the back. I could prime the system with the squeeze bulb. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
