6 members (sron48, Charles in CA, Gray_Ghost, 66flea, Wally / Montana, dt235sd), 72 guests, and 1 robot.
Topics128,050
Posts1,055,757
#81377 08/13/2007 3:25 PM
I need to remove the bellhousing to attatch my engine to the stand. There are to upper bolts on that I have found but the lower bolts I haven't. What is the procedure to remove the bell housing.
#81378 08/13/2007 4:18 PM
If your engine is a 216 or 235 you have to remove the clutch and the flywheel to get to the other bolts that hold the bellhousing on. Also remove the tin plate on the front of the bellhousing and the starter.
Fred
#81379 08/13/2007 4:56 PM
Fred is correct, I just went through that with a 235.
Ed
#81380 08/14/2007 5:25 PM
Its a 235. I will try to get it done this weekend. Thanks for the help.
